Hi All,
We are using the Hardware CSS501-SCM-INT where we wanted to enable the SSH and Web-Mgmt for accessing the device.
We followed the required configuration for the both the feature but without any luck.
Regarding SSH Feature, we found that the License SSH Server is required and we are having only Standard Feature Set.
MUMGFLB_SVC_CK1# sh version
Version: sg0720206 (7.20 Build 206)
Flash (Locked): 8.10 Build 2
Flash (Operational): 8.10 Build 2
Type: PRIMARY
Licensed Cmd Set(s): Standard Feature Set
We tried to enable the Web-Mgmt as well but here at the start we are getting the Login Page for the 1st time only, but later on we are facing the Error related TLS and SSL protocols Error.
Reference link we followed are:
Expecting a Suggestion on the same.
YSR!!!
