Cisco WAAS Auto Discovery issues
oukpaka
Find attached the datacenter configs and WAAS setup.
I think I havea challege without autodiscovery of the WAE Appliances from the Sh tfo connection summary how can I resolve this from my WAAS Setup
dstolt
Obiora,
I see a CIFS connection (445) going through your WAAS setup as fully optimized with TFO, LZ and DRE. If you are referring to "No peer or asymmetric route:" stats, are those incrementing? Normally you would see the passthrough connections in the "sh tfo conn sum". Those might be your telnet/RDP sessions to the PC for testing if you are connecting to it via the 3560 (only one WAE seeing the traffic).
Can you send a "sh tfo con sum" with the PT connections listed?
Dan
Hi Dan,
Thank for the response.
When I do a "sh stats dre" i see 12 connections but only one is active, every other connections
appears as closed. if this a problem, how could it be remedied. Also a sh tfo auto-discovery still indicates incremental counts "No peer or assymetric route " as seen in the attached file.
How do I get to resolve these. Thanks.
I have some significant improvements while downloading across the WAE aplliances but still think there is room for improvement I guess. For instance I did a 1.6MB word file across ta 512Kbps link of 5% packet loss and 600msecs link in 21secs as compared to 2mins 7secs without the WAE.
Hi Dan,
