CLI QUICK QUESTION
tbone-111
Community Member
I have my certificate and my key pair loaded onto the ace.  What command do I need to execute to pair them?
jsirstin
Level 5
Level 5
Tbone,
Are you talking about verifying that the cert and key match, or how to apply them to the config? If you are just trying to confirm that the cert and key are a match you can use the command below.
crypto verify key_name cert_name
I am also including a link that has the config for basic ssl termination. It does not go into the importing of the certs just the config.
Jim
http://www.cisco.com/en/US/products/hw/modules/ps2706/products_configuration_example09186a00809c3045.shtml
