Configuring ACE to loadbalance 4 transparent firewalls
zivweinrich
Is someone ever try to configure cisco ACE to loadbalance between 4 transparent FWs?
I will be happy to consult about this type of configuration.
Thank,
Ziv.
Sean Merrow
Level 4
Level 4
Hello Ziv,
The Configuring Firewall Load Balancing section of the ACE config guides would be a good place to get you started.  You should refer specifically to the configuration steps and config examples for Stealth FWLB.  You can also find FWLB examples on the doc wiki.
Hope this helps,
Sean
Thanks for your reply,
I saw this example, but i have a different issue,
I need to loadbalance all traffic (protocols) coming from outside to inside the network (In the inside network I have many servers located in a diffrenet Vlans and I can't configured them as part of a server farm).
Any idea how can i configure it?
Thanks.
Hi Ziv,
I'm not sure I understand your scenario.  If you want to load balance to one or more servers, they need to be configured as rservers and added to a serverfarm.
Sean
