connection between HPE 5900 4QSFP + Switch port switch to nexus 9372 switch QSPF port
11_vikasadsule
Dear all,
I going to implement CISCO ACI network and wanted to connect on of MY HP5900 QSFP 40G uplink port on cisco ACI LEAF switch 9372 switch ....so can i Connect the HP switch Uplink port (QSFP) to cisco leaf switch 9372 QSFP port directly whether it will work or not.
Rick1776
Level 5
Level 5
It depends on if both QSFP ports follow the same type of architecture. Can you share the part number for the HP QSFP and the Cisco QSFP you plan on connecting back to back?
Rick1776
Level 5
Level 5
