Console cable for WAE 574
Jan Rockstedt
Level 6
Level 6
Hi all,
Does anybody have a serial console cable, and showing how 9 pin in both end should go to?
Jan Rockstedt
Hi Jan,
Oh okay. Sorry i misunderstood your question. So are you looking for DB-9 pin out details? The console cable you have is a standard DB-9 cable.
Kanwal
Kanwaljeet Singh
Hi Jan,
The WAE 574 has female serial console port on it and you should have male console cable 9 Pin to fit into the port. Please have a look below:
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/wave/installation/574/guide/574inst.html#wp1036469
Kanwal
Sorry but this does not answer my question, as I already know that it should be 9pin to 9 pin female.
My question is what pin goes to what pin for tha cable?
Jan
Hi Jan,
Kanwal
trent.husking
Visitor
Hi Jan,
I ran into the same issue and there is little info on the pins. Purchased blank DB9 to RJ45 backshells and created our own. The pins below work with the Rollover cable conected to it to manage via Console 512/612.
RJ45
DB9
N/C
N/C
N/C
8
N/C
