content engine 565 hangs
ahmed_salah
Community Member
i have a big problem just appeared yesterday i am running content engine in
proxy transperent mode ( CE running version CE 5.3.1 (b5) ) i notice that yesterday
internet traffic on router reach its max bandwidth when i check router for
wccp status i found
1721#sh ip wccp web-cache det
No information is available for the service.
when i restart content engine all things runs ok when i recheck router i got
WCCP Cache-Engine information:
Web Cache ID: 192.168.20.4
Protocol Version: 2.0
State: Usable
Initial Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Assigned Hash Info: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Hash Allotment: 256 (100.00%)
Packets Redirected: 32146
Connect Time: 00:05:37
after around 5 minutes the error happend again
when i stop URL-filter using smart filter all things runs ok and router
seeing cache engine again without restarting content
some times when i try to stop smart filter from CE GUI i got this message
( Error: Good Site URL List: Verifier not responding. )
and smart filter does not stopped
is this means any thing
i try another thing i try to stop smart filter from CE CLI interface i got
this error
565CE(config)#no url-filter http smart enable
Verifier not responding. (Error number: 32)
Verifier didn't respond. Need to re-register verifier. (Error number: 64)
5 Replies 5
pknoops
Level 7
Level 7
I would need to check a few things here. First, it would be necessary to grab a show tech from the CE to see if the CE is going into some overload bypass. More than likely though, something is occuring on the CE where Smartfilter is hanging or crashing.
You should go onto the CE and see if there are any recent core dumps on the CE.
On the CE, CD to core_dir and do a "dir". If there are core dumps, then these would need to be analyzed.
Currently we have a very similar issue that is occuring and a bug id has been created and being worked on CSCeg50350. This particular issue looks almost identical to what you are seeing and will be fixed in a version of 5.3 when completed.
Pete..
hi,
thanks for replay pleaes find attached o/p of sh tech u ask for as i see there is no over load bypass
now
note:i made something but this happened after employees leave work i disable wccp and disable smart filter from CLI then i restart CE after that i r enable smart filter then tell now all things works fine but i am afraid that this problem will happened again
-core_dir does not conatins any files
- u just say that u have similar issue and u say that it will be fixed in ver 5.3 just i want u to know that i am running ACNS ver 5.3.1.5 b5 it is just released
regards,
ahmed
waiting your fast response
Dear Mr Salah,
I also have just received a CE 565 which I'm trying to learn how to config it and related edge router. Could you please point me to an useful link for config purposes on both units ? Thank you very much and hope you can resolve your issue soon.
netman2k5
hi,
please find attached a cisco doc on how to config basic transperent proxy caching between CE565 and wccp router
thank you very much.
