Content Engine CE565 authentication cache
d.rehfeldt
I have a Content Engine CE565 running software version CE 5.1.7
The commands <show users request-authenticated> and <show http-authcache> provide me with information on authenticated users, but I would like to know how to determine the time remaining for a user/ip address in the authcache. This is with the understanding that the authentication will timeout after the configured period of inactivity (in minutes).
Also, is there a way to remove the authentication cached for single user/ip address? Understanding that the authentication cache resides in RAM. The only command that I am aware of is <clear users request-authenticated>, which clears all authenticated users. However, this requires all users to reauthenticate. TIA
didyap
Level 11
Level 11
As far as I know, there is no way to clear a single user, only all of them by using the command you mentioned above. The command http authentication cache timeout can be used to configure the time between last access and cache removal.
