Maintain Flow Persistency
chloi
Level 2
Level 2
Hi, this is my scenario:
I had 2 CSS configured to provide active-backup loadbalancing for ldap service.
i had configure Adaptive Session Redundancy (ASR) for the boxes. My question is:
how can i maintain the persistency of a connection if the backup turn to active unit?
persistency here means that the client need not to form another connection to the server when there is a state transition occur. state transition had to be transparent to the client. The client should be able to continuous sent request to the server without forming another connection.
thanks.
hdecreis
Level 3
Level 3
If you have:
1/ active/passive VIP redun and Virtual Int redun
2/ redundant-index on the services/groups/rules
3/ ISC link between the 2 CSS
then, the persistency of a connection is maintained if the backup turn to active unit (that is, each new connection established on master CSS for a service/group/rule having a redundant-index will be duplicated as dormant flow on backup CSS, allowing "statefull" failover for the configured flows)
see: http://cco.cisco.com/en/US/partner/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a00801577ce.html#wp1032923
