Content Engine Reporting
satishy_2
Level 3
Level 3
As the Cisco CE support the SNMP mib2 parameters , So can we extract the below report from Cisco CE by using HP-OV.
Number of sites visited; most frequent
sites; bandwidth usage per site etc.
Also what is the alternate solution to get these kind of reports.
didyap
Level 11
Level 11
You can use the data from the transcation logs to make an analyis. However only the logs are available and reports have to be made manually. Here are a few urls which describe logging feature.
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns42/cnfg42/logging.htm
http://www.cisco.com/warp/public/117/cache_engine/CE_logcodes.html
