Problem with SSL certifcate on SCA
spham
Hi all,
I created a private key and generated the certificate
request. I submitted to CA provider and got back a response. I pem-paste into the SCA and when I loaded the private key and the certificate into ssl server and end. I received a error message said "key and certificate do not match". I am convinced I have a right key for that certificate. Is there a way I fix this issue? Or I have to regenerate a new key and certificate request.
Steve
owillins
Level 6
Level 6
This error normally occurs when the certificate is using a different key than it was generated with.
As far as I know you would have to regenerate a new certificate. That should work.
