Content networking with e-learning
steve-duke
Community Member
We need to connect several sites over relatively low speed WAN links. The customer wants to use fairly large video and audio files for e-learning. Can we somehow download these files over some time period and then serve them locally? Is this transparent to the end-user who hits a URL or do they need to do something unusual? Thanks.
thomas.chen
Level 11
Level 11
From what I can gather from your post I’d put cache engines at all the remote sites and serve the video from a web server at the headquarters. Then the files can be cached locally and it will be transparent to the user. Look at www.cisco.com/go/cache and www.cisco.com/go/cdn for more details.
This is more an application for the Cisco CDM/CE-507 product sets. You can place files (video or anything else) into the CDM which will distribute the content to remote 507s for local storage (the distribution uses a process known as SODA - Self-Organizaing Distribution Architecture. You can then maintain a central e-Learning portal. But when a remote users clicks a video link to a file that exists locally, that user will automatically be redirected to the local content engine to play the video. The CE-507 currently supports a RealNetworks server to play those files and can support any other video file via http-download so it is media agnostic.
dakemp
Community Member
