Cookie insert on ACE
westoncui
Community Member
We are using an ACE engine module(ACE20-MOD-K9) provide loading balancing service for two WEB servers and configured cookie for stickness. Below is the current configuration and it seems working fine now.
The problem I was facing is before use parameter-map change the http header length to 8k the stickness doesn't really working properly. User complains that their working session constantly be kicked out and redirect them to login page. By tracing traffic from a client we found that sometime ACE fails or stop insert the configured cookie, after increase the header length ACE start getting work.
Here my question is, how does the header length setup effect ACE to insert a cookie? Will the cookie insert attmpt fail if the header is longer then the maximum length configured on ACE?
sticky http-cookie appweb.apps.com appweb.apps.com_80
  cookie insert
  replicate sticky
  serverfarm appweb.apps.com_80
parameter-map type http COOKIE_PAR
  case-insensitive
  persistence-rebalance
  set header-maxparse-length 8196
  set content-maxparse-length 8096
  length-exceed continue
policy-map multi-match global
  class SNAT
    nat dynamic 1 vlan 102
  class vip_appweb.apps.com_80
    loadbalance vip inservice
    loadbalance policy lb_appweb.apps.com_80
    loadbalance vip icmp-reply active
    appl-parameter http advanced-options COOKIE_PAR
policy-map type loadbalance first-match lb_appweb.apps.com_80
  class class-default
    sticky-serverfarm appweb.apps.com_80
class-map match-any vip_appweb.apps.com_80
  2 match virtual-address 192.168.120.23 tcp eq www
Cesar Roque
Level 8
Level 8
Hi Smith,
The 'header-maxparse-length' is used to determine how many bytes the ACE parses to
check for a cookie, HTTP header, or URL.
Probably the ACE was not able to find the cookie with the default values, meaning that the bytes it was buffering were not enough to find the cookie.
Cesar R
ANS Team
--------------------- Cesar R ANS Team
