Showing results forĀ
Search instead forĀ
Did you mean:Ā
Cookie persistency problem on ACE module
gaboughanem
Level 3
Level 3
I have an ACE20-MOD-K9 with version  A2_3_6a, and i am having problems in cookie persistency. the setup contains 4 servers using round-robin algorithm and cookie persistency and that receive http traffic on port 9090. I have been receiving complains that the users are getting disconnected randomly while accessing the web application through ACE. Below is part of the config, i hope someone can shed somelight if there is any thing missing.
Note: when setting the timeout of the cookie to default or something equal to hours, the disconnection/complains gets worse.
I cannot use persistency based on ip address.
Through my research, I did not find anything that help me although i believe it is a bug but i cannot confirm it and i also cannot upgrade later that A2.3.6 on ACE20.
Kindly I appreciate any support.
George
parameter-map type http HTTP_PARAM_MAP
  case-insensitive
  persistence-rebalance
  length-exceed continue
sticky http-cookie WRKFLW GROUP1
  cookie insert
  timeout 65535
  replicate sticky
  serverfarm WORKFLOW_SVRs
policy-map type loadbalance first-match HTTPPOLICY
  class class-default
    sticky-serverfarm GROUP1
policy-map multi-match WORKFLOW_POLICY
  class WORKFLOW_CLASS
    loadbalance vip inservice
    loadbalance policy HTTPPOLICY
    loadbalance vip icmp-reply
    loadbalance vip advertise
    appl-parameter http advanced-options HTTP_PARAM_MAP
Cesar Roque
Level 8
Level 8
Try with the sticky group configured like this:
  cookie insert browser-expire
  replicate sticky
--------------------- Cesar R ANS Team
