CSM 4.1.2 - predictor forward, TCP not working
ICMP and UDP still work outbound from the real servers, but TCP doesn't. Did something change? Should I go back to 4.1.1?
TIA
Simon
9 Replies 9
It was an asymetric routing issue, don't know why it hadn't happened under 4.1.1
Adding a load of specific routes on the right VLAN fixed it.
I have got the same problem.
So, I have found that solution.And,I see your comment in this forum.
But,I don't fix it.
Let me know the how and why of it.
Thank you.
Do you have a 'predictor forward' serverfarm / vserver?
Is the real server included in a server farm already?
Can you post you config?
At First,Thank for your reply.
And, Your questions is YES.
I think that Our Config is OK.
The following is config.
module ContentSwitchingModule 6
vlan 10 server
ip address 192.168.16.223 255.255.255.128
alias 192.168.16.224 255.255.255.128
vlan 482 client
gateway 192.168.16.129
probe TEST-SERVICE http
request method head url /index.html
expect status 200
interval 20
retries 2
failed 30
serverfarm TEST-220
nat server
no nat client
failaction reassign
real 192.168.16.195
inservice
real 192.168.16.196
inservice
health retries 20 failed 120
serverfarm TEST-221
nat server
no nat client
failaction reassign
real 192.168.16.177
inservice
real 192.168.16.181
inservice
serverfarm SERVER_DIRECT
nat server
no nat client
predictor forward
sticky 220 netmask 255.255.255.255 timeout 60
sticky 221 netmask 255.255.255.255 timeout 60
vserver DIRECT_ACCESS
virtual 192.168.16.128 255.255.255.128 any
persistent rebalance
inservice
vserver TEST-220-11000
virtual 192.168.16.220 tcp 11000
serverfarm TEST-220
sticky 60 group 220
inservice
vserver TEST-220-12001
virtual 192.168.16.220 udp 12001
serverfarm TEST-220
sticky 60 group 220
inservice
vserver TEST-221-11000
virtual 192.168.16.221 tcp 11000
serverfarm TEST-221
sticky 60 group 221
inservice
vserver TEST-221-12001
virtual 192.168.16.221 udp 12001
serverfarm TEST-221
sticky 60 group 221
inservice
diagnostic cns publish cisco.cns.device.diag_results
diagnostic cns subscribe cisco.cns.device.diag_commands
redundancy
mode rpr-plus
main-cpu
auto-sync running-config
auto-sync standard
vlan internal allocation policy ascending
vlan 10,20
vlan 50
name client
vlan 462,482
interface GigabitEthernet1/1
no ip address
speed 100
duplex full
switchport
switchport access vlan 10
switchport mode access
spanning-tree portfast
interface GigabitEthernet1/2
no ip address
speed 100
duplex full
switchport
interface GigabitEthernet1/3
no ip address
speed 100
duplex full
switchport
interface GigabitEthernet1/4
no ip address
speed 100
duplex full
switchport
interface GigabitEthernet1/5
no ip address
speed 100
duplex full
switchport
switchport access vlan 482
interface GigabitEthernet1/6
no ip address
speed 100
duplex full
switchport
interface GigabitEthernet5/1
no ip address
switchport
switchport access vlan 462
interface GigabitEthernet5/2
no ip address
switchport
interface Vlan1
no ip address
interface Vlan462
ip address 172.6.46.254 255.255.255.252
interface Vlan482
ip address 192.168.16.129 255.255.255.128
ip route-cache flow
ip classless
ip route 0.0.0.0 0.0.0.0 172.6.46.253
no ip http server
HI,
the config looks more or less fine. please remove the NAT Server statement in the serverfarm SERVER_DIRECT. Normaly it shouldn't be a problem as there is no real mentioned where the CSM has to do the NATing for but I experienced strange things in the lab havig configured the server nat. They went away after I removed that command.
Could you do me the favour and take a sniffer trace in VLAN 482 and VLAN 10 when trying to connect to the servers directly and post them here?
Kind Regards,
Joerg
I had already removed the nat server in serverfarm SERVER_DIRECT.(no nat server)
But,couldn't solve it.
I had monitored my problem through EtherPeekNX.
So, I have captured file.
I'll attacted it.
This file was captured on port-channel262(the mux interface of CSM).
My problem is the following
Form client to virtual and real server.
I get OK on service including ICMP,UDP & TCP.
From real server to client.
OK on service including ICMP,UDP.
But,I cann't establish TCP connection because of TCP repeated Connect attempt.
Is there a way to control which client VLAN traffic sourced from a real will exit the CSM through? Other than static routed that is?
I don't have any config relating to question.
But,I had solved my problem.
After delete the following Config on CSM.
nat server
no nat client
predictor forward
inservice
I think that don't need 'predictor foward' in bridged-mode.
You are right, in bridged mode no predictor forward is needed.
