CSM and Proxies
mark.duffy
I've just recieved a request from a customer who wants to load balance on their CSMs connnections that have effectively come from a proxy.
So a client will connect to an ichain box to authenticate, if the successful then they will be passed on to the virtual address. They need the address that hits virtual address to be sticky so the client always gets the same server. However because the request is forwarded on from the ichains box (which is acting as a proxy) the address will always be one of the 2 ichains boxes.
Can the source address used in a load balanced rule be pulled from the X-ForwardedFor section of the HTTP request?
Many thanks
Mark
jfoerster
Level 4
Level 4
Hi Mark,
I guess this can be performed with http header stickieness but this requires CSM version 4.2 mentioned in the releasenotes (
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a00803e006a.html#wp1030587)
From a config trial:
sticky 1 ?
cookie configure sticky group cookie
header configure sticky group header
netmask configure sticky group IP netmask
ssl configure sticky group ssl
so
sticky 1 header X-ForwardedFor 10
should do the job.
But insert one more line in the config:
variable HTTP_CASE_SENSITIVE_MATCHING 0
so that the matching is no longer case sensitive.
Kind Regards,
Joerg
PS
Please let me know about the outcome I only tested it with MSIDN but it should work with this header too
jfoerster
Level 4
Level 4
Hi Mark,
sticky 1 ?
so
should do the job.
Kind Regards,
Joerg
PS
Joerg
Many thanks for the speedy response and reply, we'll give it a go and see how it works.
We are lucky this is a migration from CSS to CSM so we can select the code from day one.
Once again thanks for your help
Mark
HI Mark,
hmm did you do header stickiness with the CSS? I'm still searching for a good example on how to perform this. As far as I got things on the CSS header stickiness is not realy possible right?
Kind Regards,
Joerg
