CSM FT track-gateway
jfoerster
Level 4
Level 4
I've some question in regards of ft.
First of all the following problem:
CSM_active fails or needs to be maintained. CSM_backup takes over..
As soon as one is finished on wants to have CSM_active being the active one. Is there a timeout like in HSRP that tells the primary CSM to wait for a certain time to take over the active part again?
Same question applies to the track command. When a failover occurs due to a track issue is there a way to delay the fallback after the failing reasong (track trigger) is gone?
Kind Regards,
Joerg
Gilles Dufour
the CSM introduces a delay before a device preempt mastership.
This delay is not configurable however and I'm not exactly sure what is the value.
Regarding the gateway tracking feature, there is no delay.
Gilles.
