CSM load balancing.
nehakulsum
Level 3
Level 3
Hi ,
I have CSM module on the cat 6500 switch and the issue is the content switch module is not balancing the request to the servers.
IT only sends to one server were as it should do the load balance and send it to all the servers packets by packets.
Kindly let me know what needs to be changed on CSM (Virtual server) to do the load balancing properly.
No issues with config as confirm by another engineer.Probes been configured properly it was workingg fine before but not now.
Please have a look.
<Snippet>
Short config from device:-
vserver neha60
virtual 80.102.100.89 tcp www
serverfarm neha60
persistent rebalance
advertise
probe http
inservice
serverfarm neha60
nat server
no nat client
predictor leastconns
real 20.20.100.2:6008
inservice
real 20.20.100.2:6018
inservice
real 20.20.100.2:6088
inservice
real 20.20.100.2:6038
inservice
real 20.20.100.2:6048
inservice
real 20.20.100.6:6008
inservice
real 10.130.150.10 8012
inservice
real 20.20.100.6:6018
inservice
real 20.20.100.6:6038
inservice
real 20.20.100.10:6088
inservice
real 20.20.100.10:6018
inservice
inservice
real 20.20.100.10:6048
inservice
and there are more.....
Cisco6502#sh module csm 1 reals
20.20.100.2:6008 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.2:6018 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.2:6088 neha60 6 OPERATIONAL 29
20.20.100.2:6038 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.2:6048 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.6:6008 neha60 6 OPERATIONAL 6
20.20.100.6:6020 neha60 6 OPERATIONAL 0
20.20.100.6:6018 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.6:6038 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.6:6048 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.20:6008 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.10:6018 neha60 6 OPERATIONAL 0 ----No hits-------
20.20.100.10:6088 neha60 6 OPERATIONAL 20
20.20.100.10:6038 neha60 6 OPERATIONAL 0
20.20.100.10:6048 neha60 6 OPERATIONAL 0
</<Snippet>
regards,
Neha.
inayathulla1
Level 4
Level 4
Hi Neha,
Looks like you are hitting this bug:
CSCei26434.
Inayath.
Hi Inayath,
Thanks. But why is that only couple of servers with parameters are been hit? If bug is the cause then all the servers with any port number should not have been hit?
Thanks in advance.
Neha.
Did you try to remove some of the reals ( leave only 3 or 4 ) to see if this still happens?
