CSM module
Michal Valach
Hello, I have one question please....
I have 2 servers for loadbalancing, www page is working for everybody, but I still see total conns established=0, do you know why? Or how to check if load balancing is working? thx a lot
server1, serverfarm, state = OPERATIONAL
  address = 1.1.1.1, location = <NA>
  conns = 0, maxconns = 4294967295, minconns = 0
  weight = 8, weight(admin) = 8, metric = 0, remainder = 0
  total conns established = 0, total conn failures = 0
server2, serverfarm, state = OPERATIONAL
  address = 2.2.2.2, location = <NA>
sivaksiv
Check if you are getting any connecitons to VIP using command below. You have options to filter with specific client ip too.
show module csm slot conns
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csms/2.1.1/command/reference/s.html#wp1055505
Siva
6 Replies 6
sivaksiv
Siva
no connections
    prot vlan source                destination           state
Looks like the traffic is not passing through the CSM, hitting server directly? Do you access the VIP on CSM that loadbalances to the servers?
Siva
but user can access the page and:
server2,serverfarm, state = OPERATIONAL
I canot access VIP
To loadbalance, you should access the VIP not the server directly.
Problem resolved. Thank you sivaksiv for your help. The problem was that I was connected to standby CSM :-).
Sorry for confusion.
