CSM-S Sticky Problem with cookie
pat1848
I have a problem with the CSM-S module. I configured the following thing to achieve session persistency with cookies.
module ContentSwitchingModule 8
vlan 2341 client
description ** pdivers-in **
ip address 172.29.98.16 255.255.255.0 alt 172.29.98.17 255.255.255.0
gateway 172.29.98.1
vlan 2347 server
description ** pdivers-lb **
probe HTTP http
recover 3
interval 5
failed 10
serverfarm 2340
nat server
no nat client
real 172.29.98.100
inservice
real 172.29.98.101
inservice
probe HTTP
sticky 10 cookie SESSION insert timeout 10
vserver 2340
virtual 172.29.98.220 tcp www
serverfarm 2340
sticky 10 group 10
persistent rebalance
inservice
So it's quite a simple configuration. The strange thing: with the show sticky group 10 command i don't get any entry in the table after i did a "get Request" to the server, but the Browser receives the cookie "SESSION". In addition a sniff showed that i'm sending the cookie "SESSION".
Does anybody have a cloue, why my sticky table stays empty.
By the way, if i try stickiness with source IP, they show up in the sticky table and it works fine.
Release is 2.1(2)
Cheers
patrick
irisrios
Level 6
Level 6
The commands in this mode require the sticky feature in your user role.
To create a sticky group for cookie stickiness, enter:
host1/Admin(config)# sticky http-cookie cisco.com GROUP3
