CSM-SSL sticky group issue
cjrchoi11
when I configure as follows, the browser from client is not working properly. only showing part of the page and break the SSL session when I refresh the browser. if I just configure "sticky 60" w/o the group, works fine the sticky as expected.
why my configuration is not working properly with the group option?
sticky 100 ssl timeout 60
vserver xxx
sticky 60 group 100
Thanks in advance,
Gilles Dufour
Capture a sniffer trace and see what's going on.
When you do not specify the group, the CSM assumes this is the default sticky group 0 which is stickyness based on source ip.
Also, verify if the problem exist with all types of browser or just IE for example.
IE is well-known for not working very will with ssl stickyness because it keeps changing the sslid.
Gilles.
Thanks for rating this answer.
