CSM Sticky Connection
lbhoang
Hello, gentlemen. I have a question regarding CSM v4.2(3) in bridge mode and utilizing sticky connection. Do I need to configure a unique non-SSL sticky group for each vserver or can I reuse the same sticky group for multiple vservers? I found a couple of links discussing sticky connections but they're very brief. A link to more detailed info would be perfect. Thank you in advance.
Example:
sticky 10 netmask 255.255.255.255 timeout 15
sticky 20 netmask 255.255.255.255 timeout 15
vserver TEST1
virtual 10.10.10.10 tcp www
serverfarm TEST1
sticky 15 group 10
replicate csrp sticky
replicate csrp connection
persistent rebalance
inservice
vserver TEST2
virtual 10.10.10.20 tcp www
serverfarm TEST2
sticky 15 group 20
inservice
vserver TEST3
virtual 10.10.10.30 tcp www
serverfarm TEST3
sticky 15 group 10
inservice
Gilles Dufour
simple answer is - 1 sticky group per vserver.
If your vservers use the same exact serverfarm, you could share the sticky group.
Gilles.
