CSM to ACE conversion Tool
mark.duffy
Level 3
Level 3
Gilles made mention in a couple of posts about a tool on the ACE that can be accessed by enabling the http server and then connecting to the IP address of the ACE module.
Could somebody point me at some documentation relating to it because I can't seem to find anything.
Mark
CSM2ACE tool is accessible by pointing the browser to management ip address of ACE card.
You need to make sure that you are running http server on ACE and your Management policy allows http access.
Syed
Thanks Syed,
Is it documented anywhere? I was looking for a link I could forward on to a customer.
Many thanks
Mark
I dont think it is documented in ACE documentaion.
Syed
andrew.burns
Level 11
Level 11
Assuming the ACE module and appliance both have the same tool you can find the online user guide here:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/ace_4700/ace_171/cssaceug.htm
Andrew.
