CSM to GSS via KAL-AP: How to display vserver transitions ?
yves.haemmerli
I need to know how much time a CSM sent an Offline status for a VIP (vserver) to the GSS via KAL-AP. In other words, I want to see how match time a specific VIP reported a load = 255 to the GSS, because all real servers in the farm were unavailable or overloaded. With the command "show module csm 1 vserver name <Name>, I don't see this counter :
PORTAL-PROD, type = SLB, state = OPERATIONAL, v_index = 30
virtual = 160.213.139.14/32:26000 bidir, TCP, service = NONE, advertise = FALSE
idle = 3600, replicate csrp = connection, vlan = ALL, pending = 30, layer 7
max parse len = 4000, persist rebalance = TRUE
ssl sticky offset = 0, length = 32
conns = 0, total conns = 87
Domains:
PORTAL-PROD
Is there another way to display this value on the CLI ?
Thank you
Yves Haemmerli
yves.haemmerli
I am reposting this question, because I am investigating why the GSS shows VIP transitions via KAL-AP, while there is no real servers failures...So, I would like to see a VIP (vserver) transitions counter on the CSM, in order to coorelate what the GSS says.
Thank you for any hints,
Yves Haemmerli
