CSS 11500 Serial Management Port Parameters
sfalbe
How to change / check the baud rate, parity, and stop bits of the serial management port.
My PC is currently set to 9600,8,1,N and I am receiving garbage. Telnet is ok
Steve
mschnabe
I dont think you can change the port parameters -
Connect a console to the Console port on the CSS. Configure the console with
the following default values: 9600 baud, no parity, 8 data bits, 1 stop bit, and
flow control set to None. This is from the appendix B of the 7.10admin
Gilles Dufour
be carefull that the cable for console access is different from any other Cisco device. So, if your cable works for a Cisco router or a Cisco switch, than this is the wrong cable for the CSS.
If you search www.cisco.com for 'css console pinouts' you should find the right settings.
Gilles.
