css 11501 2WEB SLB Severs, 80 Port working load balancing, 8282 Port Not
satagraha
Hi, I am connecting 2web servers, but http 80 port is working, 8282 port is not.
On client, can open.. http://193.193.10.50/ekp/index.jsp
but Can not open ..http://193.193.x.x:8282/RDServer/index.jsp .
193.193.10.254 is default gateway on web servers... what is problem?
!*************************** GLOBAL ***************************
dns primary 168.x.x.1
ip route 0.0.0.0 0.0.x.x.193.10.254 1
!************************* INTERFACE *************************
interface e1
description " TO EKPWEB1 "
interface e2
description " TO EKPWEB2 "
interface e9
description " TO BackBone6509_4/13"
!************************** CIRCUIT **************************
circuit VLAN1
ip address 193.193.x.x.255.255.0
!************************** SERVICE **************************
service server1
keepalive type http
ip address 193.x.x.51
active
service server1_8282
string server1_8282
keepalive type tcp
keepalive port 8282
protocol tcp
port 8282
active
service server2
keepalive type http
ip address 193.x.x.55
active
service server2_8282
string server2_8282
keepalive type tcp
keepalive port 8282
protocol tcp
port 8282
active
!*************************** OWNER ***************************
owner abc
content roundrobin
vip address 193.x.x.50
add service server1
add service server2
protocol tcp
port 80
url "/*"
active
owner abc_8282
content rr_8282
protocol tcp
add service server1_8282
add service server2_8282
balance leastconn
url "/*"
port 8282
active
zgray
As a suggestion, and just for troubleshooting purposes, you might disable the string operation under the services. Since you are not using cookies to balance, then the string value applied to the service rules may not matter.
