CSS 11501 web timeout
Frank
Level 3
Level 3
I have a CSS11501 running 8.10.0.02 software. I have 2 windows 2003 web servers that connect to a backend database. I am recieving complaints that intermittently the end user is getting a session timeout.
I set the flow multiple to 2700 so the flow would be active for 12 hours, but when I issue the show flows command I see flow disappearing after just a few minutes.
Is this normal behavior?
Does my config look correct otherwise?
service A
ip address 192.168.248.17
keepalive type http
active
service B
keepalive type http
ip address 192.168.248.18
active
!*************************** OWNER ***************************
owner test1
content web
port 80
protocol tcp
add service A
add service B
vip address 192.168.248.16
balance aca
advanced-balance sticky-srcip
sticky-inact-timeout 720
flow-timeout-multiplier 2700
active
Frank
Gilles Dufour
Frank,
if the client or the server closed the connection, it will disappear.
Sniff the traffic on both side of the css and see which device is closing the connection.
Don't forget that servers also come with an idle timeout which is usually far less than 12 hours.
Gilles.
