CSS 11503 stickyness weightedrr problem
juergen.klaiber
i have a small problem with three web servers balanced by CSS.
The servers are weighted and source ip stickyness is enabled. But as soon as i activate "balance weigtedrr" in the content rule, i recieve no awnsers from the CSS, although the servers are alive.
When i switch back to "no balance" in the content rule, everthing works fine.
I am not sure, if i really need the "balance weigtedrr" command
to activate the weigted round robin, because i have no equipment to test it.
config:
service www1
ip address 10.160.1.176
port 9090
keepalive type http
weight 2
active
service www2
ip address 10.160.1.186
port 9090
keepalive type http
weight 4
active
service www3
ip address 10.160.1.182
port 9090
keepalive type http
weight 4
active
content WWW
vip address 10.160.1.121
add service www1
add service www2
add service www3
advanced-balance sticky-srcip
sticky-inact-timeout 1440
balance weightedrr
port 80
protocol tcp
active
Software version is sg0750103
thank you
juergen
pknoops
Level 3
Level 3
Hi Juergen,
If using the balance weightedrr, you actually need to specify the weight when adding the services to the content rule itself.
So in your case, when in config mode on the "content WWW" you would then type in "add service www1 weight 4" instead of using it in the service itself. You would remove it from the service.
The reason it is done this way is because you can then use that same service in a different content rule and actually specify a different weight, or no weight at all. There is more flexibility with this option.
Pete..
