CSS 11503 Web NS 75103 - inactiveTimeout problems
sthon-dbsys
Hi there,
I have a problem with the "inactiveTimeout" of tcp sessions.
I have configured no special timeout for the owner "FARM" and content 7136.
but some of the flows using this farm have an inactivity timeout of 608 sec.
Especially all flows with "Flow flg 00001119".
other flows, eg with "Flow flg 00001099" have the normal tinmeout of 16sec.
used system:
"Product Name: CSS11503-AC E0 SW Version: 07.50.1.03"
any ideas of this behaviour ?
thx in advance
greets
sascha
deetailed info:
owner FARM
content L4_TCP_7136
protocol tcp
vip address 172.21.183.235
port 7136
advanced-balance sticky-srcip
sticky-inact-timeout 10
redundant-index 30018
add service <service1>
add service <service2>
active
CSS(debug)# show flow-timeout configured
User Configured Values for Content Rule Flow Timeout
Port Content Rule Timeout
389 L4_LDAP_389 5175
636 L4_LDAP_636 5175
7232 L4_TCP_7232 225
7233 L4_TCP_7233 225
1425 L4_TCP_1425 38
1426 L4_TCP_1426 38
1427 L4_TCP_1427 38
7053 L4_TCP_7053 19
7054 L4_TCP_7054 19
389 L4_TCP_389 5175
80 L4_HTTP 23
9501 L4_TCP_9501 19
9506 L4_TCP_9506 19
9501 L4_TCP_9501 19
9506 L4_TCP_9506 19
9501 L4_TCP_9501 19
9506 L4_TCP_9506 19
CSS(debug)# show flow-timeout default
TCP/IP Application Inactivity Timeout
Port In Seconds
* Default 16
2049 NFS 2
2049 NFS 2
5190-5193 AOL Chat 180
80 HTTP 8
21 FTP Control 600
20 FTP Data 600
23 Telnet 600
sthon-dbsys
... and now the infos of the show output:
CSS(debug)# flow-agent show active_fcbs tuple 0.0.0.0 0 172.21.183.235 7136
Flow ID Src IP SPort Dst IP DPort Pr slot sub spt dpt Flow flg
8ad8db70 172.30.74.47 1877 172.21.183.235 7136 6 1 1 1 1 00001089
8a7cd5f0 172.21.190.163 1205 172.21.183.235 7136 6 1 1 1 1 00001119
8bd89dc0 172.21.187.125 1521 172.21.183.235 7136 6 2 1 1 1 00001119
8bdf6d80 172.21.190.100 1319 172.21.183.235 7136 6 2 1 1 1 00001089
8bdd0980 172.26.83.189 1671 172.21.183.235 7136 6 2 1 1 1 00001099
8aeafda0 172.22.37.123 1661 172.21.183.235 7136 6 2 1 1 1 00001099
8aa6e5c0 172.24.227.195 1521 172.21.183.235 7136 6 2 1 1 1 00001119
8bbda240 172.30.74.47 1879 172.21.183.235 7136 6 2 1 1 1 00001099
8aab89c0 172.27.116.212 1526 172.21.183.235 7136 6 2 1 1 1 00001119
8b5a2e60 172.26.18.157 1521 172.21.183.235 7136 6 2 1 1 1 00001119
detailed flow infos for flows with "Flow flg 00001119":
-> inactiveTimeout: 608
CSS(debug)# flow-agent show fcb_details 0x8b5a2e60
CSS(debug)#
Fcb Details for FCB: 0x8B5A2E60
SRC: 172.26.18.157-1521 NAT: 172.21.183.236-36220
DST: 172.21.183.235-7136 NAT: 172.21.68.28-7136
DMAC: 00-00-0c-07-ac-08 SMAC: 00-0b-be-a3-08-22
IP Hdr ChkD: 52868 TCP/UDP Hdr ChkD: 18169
TCP SequenceD: 0 Task CE: 0
BytesIn: 112714 Frames In: 1967
Dest VLAN: 159 Src/Dst Ports: 0/0
Slot/SubSlot: 2/1 SmbQ/PrcSwP: 32/0
Time Stamp / Time Out Info:
CurSecs: 11048:409, started: 3978:819 last activity: 11038
May timeout due to inactivity: Yes , inactiveTimeout: 608
Inactive Secs: 10, will timeout in: 598 secs
FCB Flags: 0x1119
0x0001 - Natting In Use
0x0000 - NOT L5 Aware
0x0000 - Non-Spoofed
0x0008 - IP/TCP Flow
0x0010 - Remote - Egress port
0x0100 - In LL List
0x1000 - Client-side
FCB FlaFlags: 0x8040
0x0040 - Is a static FCB
0x8000 - Handled an ACK
detailed flow infos for other flows as flows with "Flow flg 00001119"; eg "Flow flg 00001099":
-> inactiveTimeout: 16
CSS(debug)# flow-agent show fcb_details 0x8bbda240
CSS(debug)#
Fcb Details for FCB: 0x8BBDA240
SRC: 172.30.74.47-1879 NAT: 172.21.183.236-36893
DST: 172.21.183.235-7136 NAT: 172.21.68.32-7136
IP Hdr ChkD: 1559 TCP/UDP Hdr ChkD: 32080
BytesIn: 3879 Frames In: 18
CurSecs: 11067:158, started: 11023:756 last activity: 11027
May timeout due to inactivity: Yes , inactiveTimeout: 16
New FCB time: 120, will consider inactivity in 76 secs
Inactive Secs: 40
FCB Flags: 0x1099
0x0080 - In Proto List
kbiemer
(1) Have you tried: Keepalives?
keepalive uri "/keepalive/"
protocol tcp
port 80
string web5
keepalive frequency 20
(2) flow-timeout-multiplier 300 ****** we had similar issues with certin apps ***********
content citrix443
protocol tcp
port 443
application ssl
vip address 10.67.3.43
add service citrix443
active
Just some thoughts,
Keith
the application has no problem, all is working fine.
the questions is why I have an inactivity timeout of 608 sec, where no "flow-timeout-multiplier" is configured.
