CSS and Keepalive Script for Radius
Sbutzek
Level 3
Level 3
has anyone implemented, a keepalive script, to query a radius server via UDP?
Sven
5 Replies 5
jfoerster
Level 8
Level 8
Hi Sven,
I guess this will be sort of a problem as you have to implement the security of radius shared secret. Therefor I think only probing the port will be available no real radius probing except you do it via a dummy service on a server triggering a real radius request. The dummy service needs to be triggerd by the CSS/CSM.
Hope that helps.
Kind Regards,
Joerg
Hello Joerg,
i think you are right.
But how can i probe a UDP Port, where Radius is running?
Sven,
Did you ever figure out how to do probe the Radius UPD port? I now have to do the same thing.. Any help would be very appreciated.
Linda
Hello Linda,
not really. I think the only pussible thing is, to send data to the UDP Port an see if an icmp unreachable will be returned.
If not, the application should be running.
But i am not sure, how to detect a icmp unreachable, so we did change to a simple icmp request.
Sven
what you could do is capture a sniffer file a querry going to the radius server.
Then, convert the querry to hexadecimal and create a script to send raw data using the hexadecimal.
To the same thing with the response to the same querry. and in your script verify that the response you received is a match again using raw data and hex data.
Gilles.
