SSL module restart
marcin.mazurek
Level 2
Level 2
not very content networking specific but...
I'd like to reset SSL module in my 6509. When I try to set reload command in SSL I get this:
SSL_primary#reload at 3:00
Reload to the ROM monitor disallowed from a telnet line.
Set the configuration register boot bits to be non-zero.
and I have a register on SSL set to 0x0, but I can't find config-register command in SSL config mode. What would be the apropriate command to change register on module?
Is it possible to run "hw-module module 4 reset" to run and specific time?
tia
owillins
Level 11
Level 11
You will find the config-register command in the global config mode. You will find information on the usage of this command at http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hcf_r/cfn_02h.htm#wp1031618
I think this is not this, as in MSFC I have already config-register set to correct value but on SSL module it's still 0x0.
thx
