CSS and Oracle10gAS webcache health check
hydechicago
Both CSS LBR's HEAD and GET health check requests failed for http://ip.address.for.the.server/_oracle_http_server_webcache_static_.html, a magic URL from Oracle10gAS webcache that only resides in memory (no file exists on disk). But I can use browser or gui-less browser 'elinks' and access it via IP to that URL with no problem.
Has anyone here encountered this issue? Does anyone have solution for this?
Many thanks,
ebreniz
Level 6
Level 6
WCCP Version 2 enables a series of Content Engines, called a Content Engine cluster, to connect to multiple routers. This feature provides redundancy and a more distributed architecture for instances when a Content Engine needs to connect to a large number of interfaces. This strategy also has the benefit of keeping all the Content Engines in a single cluster, avoiding unnecessary duplication of web pages across several clusters.
http://www.cisco.com/univercd/cc/td/doc/product/webscale/webcache/ce31/config31/appx_b.htm
I observe the same problem, using CSS11506
with 08.10.1.06.
Does anybody have a clue?
