CSS config problem
jackson.ku
Level 6
Level 6
We have one CSS, the config are A/F :
!Generated on 06/20/2002 18:40:21
!Active version: ap0500002
configure
!*************************** GLOBAL ***************************
acl enable
ip route 0.0.0.0 0.0.0.0 192.192.51.250 1
!************************* INTERFACE *************************
interface e1
bridge vlan 111
interface e2
bridge vlan 111
interface e3
bridge vlan 111
interface e4
bridge vlan 111
!************************** CIRCUIT **************************
circuit VLAN1
ip address 192.192.51.12 255.255.255.0
circuit VLAN111
ip address 192.168.111.111 255.255.255.0
!************************** SERVICE **************************
service web1
active
service web2
ip address 192.168.111.2
active
service web3
ip address 192.168.111.3
active
service web4
ip address 192.168.111.4
active
!*************************** OWNER ***************************
owner MORGAN
content intra-ssh
add service web1
protocol tcp
port 22
vip address 192.192.51.11
active
owner NOU-WEB
content ftp
add service web1
application ftp-control
protocol tcp
port 21
active
content sql
add service web1
protocol tcp
port 3306
active
content web
add service web1
add service web2
add service web3
protocol tcp
port 80
active
!*************************** GROUP ***************************
group source
add service web1
add service web2
add service web3
add service web4
active
!**************************** ACL ****************************
acl 1
clause 1 permit any 192.192.51.105 destination 192.192.51.11 sourcegroup sour
clause 2 permit any 192.192.48.62 destination 192.192.51.11 sourcegroup sourc
clause 3 permit udp 192.192.50.1 destination 192.192.51.11 sourcegroup source
clause 4 permit tcp 192.192.48.0 255.255.255.0 destination content NOU-WEB/ft
clause 5 permit tcp 192.192.49.0 255.255.255.0 destination content NOU-WEB/ft
clause 6 permit tcp 192.192.50.0 255.255.255.0 destination content NOU-WEB/ft
clause 7 permit tcp 192.192.51.0 255.255.255.0 destination content NOU-WEB/ft
clause 8 permit tcp 192.192.52.0 255.255.255.0 destination content NOU-WEB/ft
clause 9 permit tcp 192.192.53.0 255.255.255.0 destination content NOU-WEB/ft
clause 10 permit tcp 192.192.55.0 255.255.255.0 destination content NOU-WEB/f
clause 11 permit tcp 140.113.112.0 255.255.255.0 destination content NOU-WEB/
clause 12 permit tcp 203.71.181.0 255.255.255.0 destination content NOU-WEB/f
clause 13 permit tcp 210.242.151.128 255.255.255.128 destination content NOU-
clause 14 permit tcp any destination content NOU-WEB/web
clause 15 permit any 192.192.51.101 destination any
clause 18 permit any 192.192.51.105 destination content MORGAN/intra-ssh
clause 16 permit udp 192.192.51.11 eq 123 destination 210.59.157.10 eq 123
clause 19 bypass udp 210.59.157.10 eq 123 destination 192.192.51.11 sourcegro
clause 20 permit any 211.23.75.18 destination content MORGAN/intra-ssh
clause 21 permit any 211.72.165.123 destination content MORGAN/intra-ssh
apply circuit-(VLAN1)
acl 2
clause 1 permit any any destination any
apply circuit-(VLAN111)
The question is : we have one backup server ( Ip address : 192.168.111.4, connected to CSS port e1 ), it can not backup other three servers ( 192.168.111.1-3, connect to CSS port e2-4 ), but if I connect CSS to L2 switch, then connect these 4 servers to L2 switch, backup is Ok. Could you give me some advise to modify CSS config to resolve the backup problem if all servers direct connect to CSS?
Best Regards,
Jackson ku
ptrigueira
Level 2
Level 2
What kind of CSS are we talking ?
What version of Webns are you running (standard vs enhanced) ?!
regards,
Gilles Dufour
could you give us information on how you test this.
Also, I don't see a configuration for the sorry server (backup)
Here is an example :
service primary1 !--- This is your main server.
ip address 10.10.10.11
keepalive type tcp
port 80
active
service primary2 !--- This is your main server.
ip address 10.10.10.12
keepalive type tcp
port 80
active
service sorry !--- This is the server you want to default to,
ip address 10.10.10.13 if the primary fails.
keepalive type tcp
port 80
active
owner Scott
content Green
vip address 172.17.63.239
protocol tcp
add service primary
primarySorryServer sorry !--- This is important here.
active
CSS150-4#
The "backup server" is a server that running backup software ( such as Legato Networker ) to backup data for other 3 servers. ( running Legato Networker Client PAK ). If all of the 4 servers are direct connect to CSS, the backup server can not backup data for other 3 servers. But if all of the 4 servers are connect to L2 switch, the L2 switch connect to CSS, the backup server can backup data for other 3 servers.
Best Regards,
Jackson Ku
