CSS doesn't work with IIS host names multi-subdomain
lanningye
We  have two servers behind CSS. Once we enable more than one host name on IIS for multi subdmain. e.g. a.test.com and b.test.com
we http to this address will be time-out. all the domain names use single IP address.
The configuration on CSS is very basic and simple. and to keep it even simpler, I have only added one service to the content for now
!*************************** GLOBAL ***************************
   ip route 0.0.0.0 0.0.0.0 xxx.xxx.140.1 1
!************************* INTERFACE *************************
interface e1
  bridge vlan 2
interface e5
  bridge vlan 3
interface e6
  bridge vlan 3
!************************** CIRCUIT **************************
circuit VLAN2
  ip address xxx.xxx.xxx.3 255.255.255.192
circuit VLAN3
  ip address xxx.xxx.10.1 255.255.255.0
!************************** SERVICE **************************
service Server1
  ip address xxx.xxx.10.3
  keepalive type http
  active
service Server2
  ip address xxx.xxx.10.4
  keepalive type http
  active
!*************************** OWNER ***************************
owner test
  content test
    add service Server1
    vip address xxx.xxx.140.4
    protocol tcp
    port 80
    active
Does anyone know what configuration I missed here?
pablo.nxh
Level 3
Level 3
Hey there,
I'm thinking your problem is related to the keepalive. Here is what happens:
Currently you've got configured keepalive type HTTP under the two services but not URL string meaning that the CSS will
do a HTTP head looking for the default website you enabled on your IIS server. Now when you enable HTTP host headers your default
website is gone, each website has its own URL and only traffic specifically destined to that URL will be sent to the domain in question.
When host headers are turned on the keepalive on the services dies and they will be brought down.
Please enable host headers and run the command show service summary and look for the status of the services!
If my assumption is correct you have two options, either set the keepalive to be TCP port 80 or you can use the scripted keepalive to check
host headers separately.
__ __
Pablo
pablo.nxh
Level 3
Level 3
Hey there,
__ __
Pablo
lanningye
Thanks Pablo! That got straight into the solution!
Thanks for your response!
Sweeeeet! Glad to help! =)
