CSS - flow permanent command
rmathiyalagan
How exactly this command benefits permanent flows?
Gilles Dufour
you don't want to play with this command unless you are trying to solve a specific problem.
This command marks flow as un-removable.
If your application does not close properly those connections and it keeps opening new ones, the system will run out of resources.
Gilles.
