CSS flow-reset-reject
catanzarom
Community Member
Hi all.
We're experiencing problem with the flow-reset-reject feature on 11500 series CSS with WebNS 7.10 installed. I cannot see any TCP RST packet on my client even if I enabled this feature on a content rule.
6 Replies 6
seilsz
Level 8
Level 8
Can you still 'ping' the server when the service is down? Note that the tcp rst is only sent if the arp entry for the server goes away.
Reference:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd6d265/1#selected_message
~Zach
Hi Zach,
I configured a test http content with only one http service with icmp keepalive. Server is down. No entry in the arp table, but tcp-rst missing.
Max.
Max,
Are you not seeing the rst for new connections, or on existing connections?
Can you post the output from (for the rule/service you are testing):
show rule all
show service
Zach
Sure,
here is the rule:
L11RM2B003# sho rule CAW FLOW_RESET all
Name: FLOW_RESET Owner: CAW
State: Active Type: HTTP
Balance: Round Robin Failover: N/A
Persistence: Enabled Param-Bypass: Disabled
Session Redundancy: Disabled
IP Redundancy: Not Redundant
L3: 10.198.226.5
L4: TCP/80
Url:
Redirect: ""
TCP RST client if service unreachable: Enabled
Rule Header Field Information
header-field-rule has not been configured for this rule.
Rule Counters:
Total Bytes: 0 Total Frames: 0
Total Redirects: 0 Total Rejects: 11
Overload Rejects: 0
Advanced Balance: None
Sticky Mask: 255.255.255.255
Sticky Inactivity timeout: 0 minutes
Sticky No Cookie Found Action: Balance
Sticky Server Down Failover: Balance
ArrowPoint Cookie Path: /
ArrowPoint Cookie Expiration: Browser Exit
ArrowPoint Cookie CSS Expired
ArrowPoint Cookie Service: Keep Current
String Match Criteria:
String Range: 1 - 100
String Prefix: ""
String Eos-Char: "" String Ascii-Conversion: Enabled
String Skip-Len: 0 String Process-Len: 0
String Operation: Match-Service-Cookie
Rule Services:
Local Load Threshold: 254
PrimarySorryServer: None
SecondSorryServer: None
VIP Ping Response Decision: Local Services Only
Name: Hits: Wgt: State: Ld: KAlive: Conn: DNS:
PROVA_BCKEND_1
0 S-1 Down 255 ICMP 0 0
Rule DNS Information
DNS Balance: roundrobin
DNS Names: DNS TTL:
Rule Hotlist Information
Hotlist: Disabled
Size: 10, Type: HitCount, Threshold 0, Interval 1
Associated ACLs: NONE
Here is the service:
L11RM2B003# sho service PROVA_BCKEND_1
Name: PROVA_BCKEND_1 Index: 40
Type: Local State: Down
Rule ( 10.199.3.10 TCP 8080 )
Redirect Domain:
Redirect String:
Keepalive: (ICMP 5 3 5 )
Last Clearing of Stats Counters: 10/11/2004 11:04:38
Mtu: 1500 State Transitions: 0
Total Local Connections: 0 Total Backup Connections: 0
Current Local Connections: 0 Current Backup Connections: 0
Total Connections: 0 Max Connections: 65534
Total Reused Conns: 0
Weight: 1 Load: 255
DFP: Disable
The problem is I can't see any RST packet when I try to connect to this VIP.
Thank you,
Max.
what you need is this
http://www.cisco.com/en/US/products/hw/contnetw/ps792/products_configuration_guide_chapter09186a008029c872.html#wp1025529
This is a new feature in 7.40
The flow-reset-reject function is for active flows.
What you want is a RESET for a new connection.
Gilles.
That's what I was looking for, thanks.
Anyway, I found another solution, adding an
url "/*"
on the content rule configuration. Maybe with the new feature, we can obtain a RST packet for L4 content too.
Thanks to everybody.
Max.
