CSS issue when using bridge mode
yueric
Community Member
I have 2 CSM installed on 2 6509 each,and configured as bridge mode.One is acting active,another is standby.I know that client and server vlan have to use same IP,but I'm confused that the IP on standby CSM,does it need to differ from active CSM vlan IP or not?
Gilles Dufour
you got a reply for this question on the other post.
The solution is to use the command 'alias' to configure a shared ip address on both CSM.
They also need to have a different address.
Gilles.
