WMT Stream Splitting not working
crwhite
Community Member
I am attempting to use a CE565 for unicast in multicast out stream splitting. I have the Unicast In Unicast Out working but can not get the Multicast Out. Basic setup is a Windows Media 7 Server encoding to port 1111 with a broadcast publishing point called station1. I also setup a broadcast alias in the CE called station1 that points to .asx file created when I setup the broadcast point on the Windows Media Server. I have also setup a Multicast Station on the CE called mcstation1 set a multicast address; port; and media source which is the .asx file from the Windows Media server. When I enter the CDN URL for the multicast station on the content engine Windows Media player opens then generates a file not found error. A sniffer trace shows that the CE565 sends an HTTP 404 error.
Has anyone out there successfully setup Unicast In - Multicast out using ACNS 5.0.11? If so would you share you configuration?
owillins
Level 11
Level 11
Have you seen bug CSCdx64276? Changing the mtu should resolve the issue
crwhite
Community Member
It is worth a try, the bug report stated that multicast out fails after 20 minutes. I am having a problem to get multicast out to start.
