09-13-2011 03:42 PM
service Server1:80
ip address 10.10.10.34
protocol tcp
port 80
keepalive type http
keepalive uri "/test.asp"
active
service Server2:80
protocol tcp
port 80
keepalive type http
ip address 10.10.10.35
active
owner Ow1
content LBR1:80
vip address 192.168.1.159
port 80
protocol tcp
url "/*"
balance weightedrr
add service Server1:80
add service Server2:80
advanced-balance sticky-srcip
sticky-inact-timeout 21
flow-timeout-multiplier 8
active
service Server1:80
protocol tcp
port 80
keepalive type http
active
service Server2:80
protocol tcp
port 80
keepalive type http
active
owner OW1
content LBR2:80
vip address 192.168.1.98
protocol tcp
port 80
url "/*"
balance weightedrr
active
All services are alive all the time and both contexts are alive all the time.
when user tries to access LBR2:80's URL it works all the time. but when user tries to access LBR1:80's url then it works sometimes and some times it doesn't work.
could you advise what the issue could be?
09-13-2011 11:56 PM
When the SYN comes in the CSS will first check for the srcip in the sticky database
and if it finds a match will forward to the stuck server. If the source ip is not
in the sticky database the request will be load balanced using weightedrr and
a server selected. That sticky server will then be added to the sticky database.
If the sticky-srcip is used between 2 content rule, it will use separate sticky table.
You may need to take packet capture to understand what is really failing along with
a following outputs :sh flow sh rule Ow1 LBR1:80 ser
regards
Andrew
