CSS Load Balancing
wasiimcisco
Level 7
Level 7
I am new to CSS. I have CSS 1150 with IOS 7.3. I want to load balancing two servers 192.168.210.55 and 192.168.210.56 on port 80.
My CSS is connected in single arm configuration. Core switch is dong the Inter VLAN routing and CSS is connected in the VLAN 200 access Port.
Servers and CSS are connected to same Layer 3 switch.
CSS is in VLAN 200  (192.168.200.10)
Servers are in VLAN 210
Below is the configuration of my CSS
CSS11501(config)# show run
!Generated on 04/03/2011 16:47:41
!Active version: sg0730106
configure
!*************************** GLOBAL ***************************
  username net des-password xxxxxx superuser
  logging subsystem flowmgr level debug-7
  logging disk log.log
  ip route 0.0.0.0 0.0.0.0 192.168.200.1 1
!************************* INTERFACE *************************
interface e1
  phy 100Mbits-FD
  bridge port-fast enable
  bridge vlan 2
interface e2
  bridge vlan 2
  phy 100Mbits-FD
interface e4
  phy 100Mbits-FD
interface e8
  phy 100Mbits-FD
!************************** CIRCUIT **************************
circuit VLAN1
  ip address 192.168.200.10 255.255.255.0
!************************** SERVICE **************************
service Citrix_Xenapp
  ip address 192.168.210.55
  keepalive port 80
  active
service Citrix_Xenapp_2
  ip address 192.168.210.56
  keepalive port 80
  active
!*************************** OWNER ***************************
owner ENOC_Citrix_XENAPP
  content Citrix_XENAPP
    add service Citrix_Xenapp
    add service Citrix_Xenapp_2
    vip address 192.168.200.52
    protocol tcp
    port 80
    active
CSS11501(config)# show service
Services (3 entries):
Name: Citrix_Xenapp     Index: 0
  Type: Local            State: Alive
  Rule ( 192.168.210.55  ANY  ANY )
  Session Redundancy: Disabled
  Redirect Domain:
  Redirect String:
  Keepalive: (ICMP   5   3   5 )
  Last Clearing of Stats Counters: 04/03/2011 16:38:49
  Mtu:                       1500        State Transitions:            14
  Total Local Connections:   0           Total Backup Connections:     0
  Current Local Connections: 0           Current Backup Connections:   0
  Total Connections:         0           Max Connections:              65534
  Total Reused Conns:        0
  Weight:                    1           Load:                         2
  DFP:                       Disable
Name: Citrix_Xenapp_2   Index: 6
  Rule ( 192.168.210.56  ANY  ANY )
  Redirect Domain:
  Redirect String:
  Last Clearing of Stats Counters: 04/03/2011 16:39:40
  Mtu:                       1500        State Transitions:            12
  Total Local Connections:   1           Total Backup Connections:     0
  Total Connections:         1           Max Connections:              65534
  Weight:                    1           Load:                         2
  DFP:                       Disable
CSS11501(config)# sh version
Version:               sg0730106 (07.30.1.06)
Flash (Locked):        07.20.2.06
Flash (Operational):   07.30.1.06
Type:                  PRIMARY
Licensed Cmd Set(s):   Standard Feature Set
CSS11501(config)# sh run
!Generated on 04/03/2011 17:39:46
configure
  username net des-password xxxxx superuser
interface e1
  phy 100Mbits-FD
  bridge vlan 2
interface e2
  bridge vlan 2
  phy 100Mbits-FD
interface e4
  phy 100Mbits-FD
interface e8
  phy 100Mbits-FD
circuit VLAN1
  keepalive port 80
  active
  keepalive port 80
  active
    protocol tcp
    port 80
    active
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
  DFP:                       Disable
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
  DFP:                       Disable
CSS11501(config)# show content
Content Database:
   Pieces of content for module: 1
                   Total Content: 56
CSS11501(config)# show owner
Owner Configuration:
Billing Info:
Address:
Email Address:
DNS Policy:     none
Case Matching:  Insensitive
CSS11501(config)# show owner ?
  <cr>                Execute command
  ENOC_Citrix_XENAPP
CSS11501(config)# show owner ENOC_Citrix_XENAPP ?
  statistics          Show owner statistical information
Billing Info:
Address:
Email Address:
DNS Policy:     none
CSS11501(config)# show owner ENOC_Citrix_XENAPP statistics
Owner Statistics for <ENOC_Citrix_XENAPP>:
DNS Policy:                        None  Case Sensitivity:                   Off
Hits:                                 1  Reject Overload:                      0
Bytes:                               52  Reject No Services                    0
Frames:                               1  Drops                                 0
Redirects                             0  NAT Translations:                     0
Spoofs:                               0
CSS11501(config)#
The load balaning IP is 192.168.200.52 but I cant ping this virtual IP and cant telnet on port 80 on this IP address.
CSS11501(config)# ping 192.168.205.55
Pinging 192.168.205.55 1 time(s)...
Working(-) 0/1
0% Success.
%% Ping Failure
CSS11501(config)# ping 192.168.210.55
Pinging 192.168.210.55 1 time(s)...
Working(-) 1/1
100% Success.
CSS11501(config)# ping 192.168.210.56
Pinging 192.168.210.56 1 time(s)...
Working(-) 1/1
100% Success.
CSS11501(config)# ping 192.168.210.1
Pinging 192.168.210.1 1 time(s)...
Working(-) 1/1
100% Success.
CSS11501(config)# ping 192.168.200.1
Pinging 192.168.200.1 1 time(s)...
Working(-) 1/1
100% Success.
Network connectivity is there. Please let me know what I am missing and how to solve this problem.
Thanks in advance.
12 Replies 12
wasiimcisco
Level 7
Level 7
Dear All,
Can anybody help me out.
Your servers on on vlan 210?  Sounds like traffic isn't being sent symetrically back through the CSS.   You can implement what is called source nat, which enables the CSS to forward the traffic with the source IP and mac address of an IP defined in a nat configuration on the CSS.  This will force traffic back through the ACE.
In addition, if you have the CSS in one arm mode, you will require policy based route to catch both client side and server side traffic and set IP next hop to appropriate IP on the CSS (VRRP address).
To configure source nat you can refer to the following:
http://www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/css11500series/v8.20/configuration/content_lb/guide/SGrp.html
Here is an example of configuring a CSS in one arm mode:
http://www.cisco.com/image/gif/paws/49841/css_asr_config.pdf
And one more thing.. You may want to consider upgrading your WebNS from 7.30 to 8.20x.. 7.30 is EOS.
Thanks.
Stephen McCabe
Thanks for the reply, But I have modified my configuration. Now I am load balancing VLAN 200 Servers where the CSS also located in the same VLAN. Attach is the updated configuration.
I can only ping the VIP but not able to telnet on VIP (192.168.200.65 80).
configure
  username net des-password net@dmin superuser
  no restrict web-mgmt
interface e1
  phy 100Mbits-FD
  bridge vlan 2
interface e2
  bridge vlan 2
  phy 100Mbits-FD
interface e4
  phy 100Mbits-FD
interface e8
  phy 100Mbits-FD
circuit VLAN1
  keepalive port 80
  active
  keepalive port 80
  active
service ENOC_EFAX_1
  ip address 192.168.200.66
  keepalive type none
  protocol tcp
  port 80
  active
service ENOC_EFAX_2
  ip address 192.168.200.67
  keepalive type none
  port 80
  protocol tcp
  active
    protocol tcp
    port 80
    active
owner ENOC_EFAX
  content EFAX
    add service ENOC_EFAX_2
    add service ENOC_EFAX_1
    vip address 192.168.200.65
    protocol tcp
    port 80
    active
!*************************** GROUP ***************************
group EFAX
  active
CSS11501(config)# show flow
  flow-timeout        Display flow-timeout values.
  flows               Show flow summary information
CSS11501(config)# show flow 0.0.0.0
%% Invalid input detected at '^' marker.
CSS11501(config)# show flows 0.0.0.0
Src Address     SPort Dst Address     DPort NAT Dst Address Prt InPort  OutPort
192.168.80.89   4567  192.168.200.65  80    192.168.200.67  TCP e8        e8
192.168.200.67  80    192.168.80.89   4567  192.168.80.89   TCP e8        e8
192.168.80.89   2474  192.168.200.10  23    0.0.0.0         TCP e8        Ipv4
Services (5 entries):
  Redirect Domain:
  Redirect String:
  Last Clearing of Stats Counters: 04/04/2011 21:57:17
  Mtu:                       1500        State Transitions:            0
  Weight:                    1           Load:                         2
  DFP:                       Disable
  Redirect Domain:
  Redirect String:
  Weight:                    1           Load:                         2
  DFP:                       Disable
Name: ENOC_EFAX_1       Index: 1
  Rule ( 192.168.200.66  TCP  80 )
  Redirect Domain:
  Redirect String:
  Keepalive: (NONE   5   3   5 )
  Weight:                    1           Load:                         2
  DFP:                       Disable
Name: ENOC_EFAX_2       Index: 2
  Rule ( 192.168.200.67  TCP  80 )
  Redirect Domain:
  Redirect String:
  Total Local Connections:   2           Total Backup Connections:     0
  Current Local Connections: 1           Current Backup Connections:   0
  Total Connections:         2           Max Connections:              65534
  Weight:                    1           Load:                         2
  DFP:                       Disable
CSS11501(config)# show service summary
Service Name                     State     Conn  Weight  Avg   State
                                                         Load  Transitions
Citrix_Xenapp                    Alive         0      1     2            0
Citrix_Xenapp_2                  Alive         0      1     2            0
ENOC_EFAX_1                      Alive         0      1     2            0
ENOC_EFAX_2                      Alive         1      1     2            0
CSS11501(config)# show rule
Content Rules:
///\\\  The Duke of Url.
{ O--O }
Name:                    EFAX   Owner:               ENOC_EFAX
State:                 Active   Type:                     HTTP
Balance:          Round Robin   Failover:                  N/A
Persistence:          Enabled   Param-Bypass:         Disabled
IP Redundancy:    Not Redundant
L3:         192.168.200.65
L4:         TCP/80
Url:
Redirect: ""
TCP RST client if service unreachable: Disabled
Rule Services & Weights:
1: ENOC_EFAX_1-Alive, S-1
2: ENOC_EFAX_2-Alive, S-1
Name:           Citrix_XENAPP   Owner:      ENOC_Citrix_XENAPP
L3:         192.168.200.52
L4:         TCP/80
Url:
Redirect: ""
1: Citrix_Xenapp-Alive, S-1
2: Citrix_Xenapp_2-Alive, S-1
Content Database:
                   Total Content: 56
Billing Info:
Address:
Email Address:
DNS Policy:     none
Billing Info:
Address:
Email Address:
DNS Policy:     none
CSS11501(config)#
Please let me know what I am missing and also one link is not working.
Since you are sourcing the connections from the client side you need to add the services under the source group as destination services:
For example:
add destination service ENOC_EFAX_1
  add destination service ENOC_EFAX_2
Thanks for the prompt reply, Do I need to bridge my CSS e8 interface in VLAN 200 where the servers are located. Currently port where the CSS is connected is acccess port for VLAN 200.
CSS11501(config)# show circuits
        Operational
Circuit name  Circuit State     IP Address       Interface(s)   Status
VLAN1         active-ipEnabled  192.168.200.10   e8              Up
Now how can i load balance my other servers located in Differenet VLANS. The link you sent me is not working. Do i need to create Trunk port etc in order to communicate with multiple VLAN.
Yes.. I assumed that was in there.. You will need to setup either a trunked interface or have two L3 interfaces in each VLAN 200/201.. That will fix the issue.
I tried configuring the trunk port but I am not able to do this. After making the trunk i cant ping or access the CSS though the port on the core switch is showing up . I want to load balance servers located in VLAN 200 and VLAN 3.
The following is the config that I am doing on the core switch as well as on the content switch.
ENOCDC_CORE02#sh running-config interface gigabitEthernet 2/7
Building configuration...
Current configuration : 140 bytes
interface GigabitEthernet2/7
description connected to the ENOC_CSS
switchport
switchport mode trunk
no ip address
end
CSS11501(config)# sh trunk
Port VLAN Default VLAN
e7 VLAN3 None
VLAN200
!Generated on 04/05/2011 11:43:01
configure
interface e1
phy 100Mbits-FD
bridge vlan 2
interface e2
bridge vlan 2
phy 100Mbits-FD
interface e4
phy 100Mbits-FD
interface e7
trunk
vlan 3
vlan 200
interface e8
phy 100Mbits-FD
circuit VLAN1
keepalive port 80
active
keepalive port 80
active
service ENOC_EFAX_1
keepalive type none
protocol tcp
port 80
active
service ENOC_EFAX_2
keepalive type none
port 80
protocol tcp
active
protocol tcp
port 80
active
owner ENOC_EFAX
content EFAX
protocol tcp
port 80
active
group EFAX
active
Operational
VLAN1 down-ipEnabled --
VLAN2 down-ipDisabled --
VLAN3 down-ipDisabled --
VLAN200 down-ipDisabled --
CSS11501(config)# show bridge ?
forwarding Bridge Forwarding Table
port-fast Bridge port-fast state
status Bridge spanning-tree status
CSS11501(config)# show bridge status
VLAN1 STP State: Enabled
VLAN1: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 80-00-00-0e-d7-93-5e-74
Bridge ID: 80-00-00-0e-d7-93-5e-74
Root Port Desg
Port State Designated Bridge Designated Root Cost Cost Port
VLAN2 STP State: Enabled
VLAN2: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 80-00-00-0e-d7-93-5e-75
Bridge ID: 80-00-00-0e-d7-93-5e-75
Root Port Desg
VLAN3 STP State: Enabled
VLAN3: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 80-00-00-0e-d7-93-5e-77
Bridge ID: 80-00-00-0e-d7-93-5e-77
Root Port Desg
e7-3 Dis 00-00-00-00-00-00-00-00 00-00-00-00-00-00-00-00 0 19 0000
VLAN200 STP State: Enabled
VLAN200: Root Max Age: 6 Root Hello Time: 1 Root Fwd Delay: 4
Designated Root: 80-00-00-0e-d7-93-5e-76
Bridge ID: 80-00-00-0e-d7-93-5e-76
Root Port Desg
e7-200 Dis 00-00-00-00-00-00-00-00 00-00-00-00-00-00-00-00 0 19 0000
CSS11501(config)# show arp
ARP Resolution Table:
IP Address MAC Address Type Port
I am following this document for the trunk configuration.
http://www.cisco.com/image/gif/paws/21303/css_dot1q.pdf
Please let me know how to achieve this.
I tried different combinnation of configuration but no luck.
Also I have requirement of Server which is communicating on multiple ports (RightFax Server). How can i load balance TCP 80, 443, 15020, 15021 located in the same Server.
I can see the range command but I dont have a range I have multiple ports.
Without seeing your entire configuration of your adjacent router which you are doing some sort of PBR on, the sourcenat configuration will allow flows to symetrically flow through the CSS and I believe we see that in your output of show flows..
To load balance to different tcp services on the CSS you can do one of two things.. You can stand up new VIP addresses (unique IP and port content rules), or you can use the same VIP, just define same IP under multiple content rules, for example:
owner ENOC_EFAX
content EFAX
protocol tcp
port 80
active
owner ENOC_EFAX
content EFAX
add service ENOC_EFAX_2_443 <-- create corresponding services for these
add service ENOC_EFAX_1_443 <-- create corresponding services for these
protocol tcp
port 443
active
owner ENOC_EFAX
content EFAX
add service ENOC_EFAX_2_15543 <-- create corresponding services for these
add service ENOC_EFAX_1_15543 <-- create corresponding services for these
protocol tcp
port 15543
active
wasiimcisco
Level 7
Level 7
Ok i will try that but please let me know y trunk ia not working 4 me.
I have core switch 6509 where all vlans are configured like vlan 3 (192.168.210.0) and vlan 200 (192.168.200.0)
Simple trunk config on switch and CSS please let me know how to fix it
You need to have your Circuit in VLAN 200.  Otherwise the CSS will not arp out and/or respond to arp broadcasts on vlan 200
i tired the following command but i was not able to even ping my gateway.
I remove circuit VLAN1 and created the follwoing config
circuit VLAN200
i have tried multiple options but unable to configure trunk with the core switch. I can only load balance servers in VLAN 200 but cant do the same on VLAN 3 and other VLAN.
Please let me know how can I configure trunk so that i can do the load balance on other VLANs.
