CSS Not Load-Balancing
collinss
Community Member
We have a CSS switch running 4.01 (Build 50). We are load-balancing connections to dual servers behind the CSS. When the service to one of the servers goes down/suspended then returns to active we don't get any new connections to that service, unless we reboot the switch. Does anyone have any ideas on why this might be happening? Also, I can post the config/rules if anyone can help.
pknoops
Level 7
Level 7
Are you using a sticky method ? Can you post the rule associated with this ?
thanks
collinss
Community Member
Here is the rule...
> Name: IBOFX_Rule Owner: IB
Author: Local Index: 1
State: Active Type: HTTP
IP Redundancy: Master
L3: 10.21.25.111
L4: TCP/80
Url: /*
URQL:
EQL:
DQL:
Header Field Group:
Total Bytes: 105134367 Total Frames: 234433
Total Redirects: 0 Total Rejects: 4
Overload Rejects: 0
Balance: Round Robin
Advanced Balance: None
Sticky Mask: 255.255.255.255
Sticky Inactivity timeout: 0 minutes
Sticky No Cookie Found Action: Balance
Sticky Server Down Failover: Balance
ArrowPoint Cookie Path: /
ArrowPoint Cookie Expiration: Browser Exit
ArrowPoint Cookie Text: None
ArrowPoint Cookie Url: None
Arrowpoint Cookie display url in header: Enabled
String Match Criteria:
String Range: 1 - 100
String Prefix: ""
String Eos-Char: "" String Ascii-Conversion: Enabled
String Skip-Len: 0 String Process-Len: 0
String Operation: Match-Service-Cookie
Redirect: ""
Persistence: Enabled
Param-Bypass: Disabled
Services:
Local Load Threshold: 254
PrimarySorryServer: None
SecondSorryServer: None
Name: Hits: Wgt: State: Ld: KAlive: Conn: DNS:
IBOFX1 46,461 S-1 Alive 2 SCRIPT 7 0
IBOFX2 48,607 S-1 Alive 2 SCRIPT 5 0
DNS Names: DNS TTL:
DNS Balance: roundrobin
Hotlist: Disabled
Size: 10, Type: HitCount, Threshold 0, Interval 1
mitch.erickson
Community Member
We are having the same issue, did you ever resolve it ?
What we notice is that if a request comes to a service before the switch notices that it is down and tries to send a request to it, it never gets another connection. I have to stop the service then start it again to resolve it.
I would love to hear if you have solved this or not.
thanks
We have not resolved the issue. We tried upgrading to a newer IOS, but it did not correct the problem. We are currently reviewing our configuration to make sure that we have all the rules setup properly.
