CSS not passing Traffic anymore
We have CSS11503 in a box to box redundancy configuration setup and it has been working for a while without any issues. We recently changed the servers in our test web farm and from then on we are not able bring them online through the VIP address. State shows that they are down even when the servers are up and running.Below is the current config on the CSS
!Active version: sg0730005
configure
!*************************** GLOBAL ***************************
ip redundancy
app
app session 172.16.30.2
ip route 0.0.0.0 0.0.0.0 172.94.23.65 1
!************************* INTERFACE *************************
interface 1/1
bridge vlan 162
interface 1/2
bridge vlan 163
interface 2/1
bridge vlan 162
admin-shutdown
interface 2/2
bridge vlan 163
admin-shutdown
interface 2/4
admin-shutdown
interface 2/8
bridge vlan 167
!************************** CIRCUIT **************************
circuit VLAN162
redundancy
ip address 172.94.x.66 255.255.255.224
circuit VLAN163
redundancy
ip address 172.94.x.145 255.255.255.240
circuit VLAN167
ip address 172.x.30.1 255.255.255.0
redundancy-protocol
!************************** SERVICE **************************
service server4519
ip address 172.x.23.153
active
service server4525
ip address 172.x.23.152
active
service server6349
ip address 172.x.23.146
active
service server6350
ip address 172.x.23.147
active
service server6351
ip address 172.x.23.151
active
service server6352
ip address 172.x.23.149
active
!*************************** OWNER ***************************
owner prod
content web-servers
vip address 172.x.23.81
port 443
protocol tcp
balance aca
add service server6352
add service server6351
add service server6350
add service server6349
active
owner testweb
content net-websrvs
vip address 172.x.23.84
balance leastconn
add service server4525
protocol tcp
port 443
url "/*.aspx"
active
content test-websrvs
protocol tcp
port 443
add service server4519
balance leastconn
active
Appreciate your valuble inputs on this issue.
Thanks in Advance
michael.e.reid
The servers have no keepalive so there should be no issue with the CSS seeing them as down. Only thing I can think off if you can't get to them via the VIP is you maybe need to point the servers default gateway to the CSS circuit address ?
You are not (apparently) doing any source NATting so perhaps the route to the client IP is to a router first. Then you may get a assymetric router.
cheers,
Mike
Servers default gateway is pointed to CSS circuit address and I can see traffic going through the CSS when I access the server directly. I can ping the servers from CSS and also from the servers to CSS but still it shows as down
I could bring the servers online by setting the keepalives to none.
Thanks for the help
you should move away from 7.30(0.5)
What you have seen is probably due to a known defect [sorr don't habe the number].
I would recommend the latest 8.10 image.
Gilles.
