CSS "flow display <flow identifier>" - timestamp
sthon-dbsys
does anyone know, how to interprete the timestamp of
"Time last frame was seen = <time>"
in "flow display <flows identifier>.
This value seems to be an absolut timestamp, but I don´t know how could I find out the real time.
In the example the value is "42629":
Time last frame was seen = 42629
What what does this value means.
complete output:
css01-23(debug)# flow active-list
Flow ID Src IP SPort Dst IP DPort Pr IgrsPort EgrsPort Flow flg
04010064 172.29.148.171 389 172.29.27.133 52440 6 01203240 00201940 822a2a00
04010923 172.29.148.171 389 172.29.27.133 56537 6 01203240 00201940 822a2a00
css01-23(debug)# show clock
Date: 03-19-2004
Time: 10:20:17
TimeZone: mez: +01:+00:+00
css01-23(debug)#
css01-23(debug)# flow display 0x04010064
Flow found on SP on Slot 2, Subslot 1
Detailed information for FlowId: 0x04010064, FpId: 0x844A5A40:
Ingress port = 0x01203240 Egress port = 0x00201940
State of this flow ( flow flags ) = 0x822a2a00 0x00
Partner flow id = 0x400ff8e
FCB flags = 0x00000419
Route Id = 0x8a63ac90
Host Id = 0x8a6d1480
Total number of SYNs received for this flow = 0
WCC cookie stat for this flow = 0
Protocol is TCP
IP: Source = 172.29.148.171-389 Dest = 172.29.27.133-52440
NAT IP: Source = 172.29.149.147-389 Dest = 172.29.27.133-52440
NAT tcp seq num delta used in L5 spoofing = 0x00000000
Flow statistics bytesIn = 0 framesIn = 0
Src macaddr = 00-0b-fd-be-c6-7d Dest macaddr = 00-01-f4-16-e5-e6
Out of sequence discards = 0
Session Redundancy State: Active
Previous Flow ID: 0x0
Local Flow ID: 0x4010064
Date: 03-19-2004
Time: 10:24:54
Protocol is TCP
regards
sascha
ok.
From the code.
CurSecs: 315164:145 means 315164sec and 145 msec.
Last activity means the time when a packet was seen last time in sec.
The time is a value in seconds since boot.
So you should do CurSecs - last activity to have the
idle time.
Gilles.
Gilles Dufour
Sascha is this a 1st gen or 2nd gen CSS ?
If 2nd gen, you should actually use a different command.
'flow-agent show active_fcbs'
then
'flow-agent show fcb_details 0x'
With the 2nf gen, you can poll the flow-agent that is responsible to do the fastswitching.
It will give you better info then the old command which gives only information seen at software level.
Gilles.
Hi Gilles,
thanks for feedback, the cmd works:
css01-23(debug)# flow-agent show active_fcbs
Flow ID Src IP SPort Dst IP DPort Pr slot sub spt dpt Flow flg
83d4cb60 172.29.148.168 81 172.19.28.165 2015 6 2 1 1 1 00000099
83e31160 172.29.148.168 81 172.26.54.87 1963 6 2 1 1 1 00000099
83a2f3a0 172.29.148.171 389 172.29.148.170 16034 6 2 1 1 1 00000119
--Cancelled---
css01-23(debug)# flow-agent show fcb_details 0x8394a140
css01-23(debug)#
Fcb Details for FCB: 0x8394A140
SRC: 172.29.148.171-389 NAT: 172.29.149.146-389
DST: 172.29.148.170-15970 NAT: 172.29.97.219-14786
DMAC: 00-01-f4-16-e5-e6 SMAC: 00-0b-fd-be-c6-7d
IP Hdr ChkD: 12776 TCP/UDP Hdr ChkD: 13960
TCP SequenceD: 0 Task CE: 0
BytesIn: 246 Frames In: 4
Dest VLAN: 101 Src/Dst Ports: 0/0
Slot/SubSlot: 2/1 SmbQ/PrcSwP: 32/1
Time Stamp / Time Out Info:
CurSecs: 314997:428, started: 150399:756 last activity: 150399
May timeout due to inactivity: No , inactiveTimeout: 0
FCB Flags: 0x0119
0x0001 - Natting In Use
0x0000 - NOT L5 Aware
0x0000 - Non-Spoofed
0x0008 - IP/TCP Flow
0x0010 - Remote - Egress port
0x0100 - In LL List
0x0000 - Server-side
FCB FlaFlags: 0x8040
0x0040 - Is a static FCB
0x8000 - Handled an ACK
how could I interprete the following line of the Time Stamps ?
CurSecs: 315164:145, started: 150399:756 last activity: 150399
my goal is to find a parameter to see how long the session is inactive !
regards
sascha
ok.
From the code.
idle time.
Gilles.
that looks fine.
thanks
sascha
