CSS Redirection problem
cdicesare
Community Member
I use a CSS 11500. I've problem of redirection HTTPS with Mozilla and Opera (it seems there are no problem with Internet Explorer).
Mozilla use a URL http://www.example.com:443/blabla instead of https://www.example.com/blabla.
Here my CSS configuration
ssl-proxy-list SSL-PROXY
ssl-server 20
ssl-server 20 cipher rsa-with-rc4-128-md5 XXXXXXXXXXXXXX
ssl-server 20 vip address X.X.X.X
ssl-server 20 rsacert certXXXX
ssl-server 20 rsakey keyXXXX
ssl-server 21
ssl-server 21 cipher rsa-with-rc4-128-md5 X.X.X.X 80
ssl-server 21 rsacert certXXX
ssl-server 21 rsakey keyXXX
ssl-server 21 vip address X.X.X.X
ssl-server 20 http-header prefix "SSL"
ssl-server 20 urlrewrite 1 www.example.com sslport 443 clearport 80
active
Thank you in advance for your help
Cedric
5 Replies 5
Gilles Dufour
I don't see why the response would be different for IE and mozilla.
Can you get us a sniff of the server traffic, to see what the redirect looks like.
Gilles.
Indeed, the problem isn't the web navigator after to deep with tcpdump.
The problem is it misses the / at the end of the URL !
https://xxx.example.com/blabla => the redirect doesn't work => http://www.example.com:443/blabla
https://xxx.example.com/blabla/ => the redirect work !!
Our customer don't wish modify their webserver apache. It's possible to find a solution with the CSS ? With a specifiq redirector rule ?
Best Regards
Cédric
Cedric,
create a rule like this
owner ....
content redirect1
vip address x.x.x.x
port 80
url "/blabla"
redirect "https://...../blabla/"
active
Gilles.
And you should probably add a wildcard to ensure your redirect will work for every addresses used.
NO !!!!!
do not put a wildcard as it would match the redirect link as well and you will enter in a loop.
Just copy it the way it is.
Gilles
CSS/CSM/ACE Guru
