CSS SNMP Trap for Firewall VRRP issue
s.srivas
Is there a way to genarate trap from CSS for Firewall (Not PIX) VRRP problem.
Similar to the existing service traps
(snmp trap-type enterprise service-transition
the suggestion applies to vrrp as well.
In this case, you can configure the phyiscal ip address if you want to monitor each firewall individually or the VRRP/shared ip address if you just want to monitor the firewalls as a single entity.
Gilles.
Gilles Dufour
not sure what you need exactly.
Are you doing firewall loadbalancing and are you looking for a trop when a firewall goes down ?
Or is your firewall simple the default gateway for the CSS and you want to detect when it goes down or switchover ?
One suggestion would be to create a service for the firewall ip address you want to monitor.
This service will have an icmp keepalive by default and if the firewall goes down, the css will generate a trap for the service going down.
Gilles.
Gilles,
Thanks for the very useful replies.
Yes we are doing firewall loadbalancing in some networks while using simple firewalls on other networks.
What is a trop?
Is your suggestion to create a service applicable to vrrp (Load balancing).
Gilles.
