CSS to ACE - rserver range loadbalance issue?
ctopaloglu
Community Member
We are replacing CSS with ACE.
CSS_Config
service apps1
ip address 10.4.11.1 range 3
keepalive type http
keepalive frequency 15
active
service apps2
ip address 10.4.12.1 range 3
keepalive type http
active
owner webapps
content webapps-rule
add service apps1
add service apps2
advanced-balance sticky-srcip
sticky-inact-timeout 480
vip address 10.4.10.1 range 3
balance leastconn
sticky-serverdown-failover redirect
ACE_Config
rserver host APPS1-01
inservice
rserver host APPS1-02
inservice
ip address 10.4.11.2
rserver host APPS1-03
inservice
ip address 10.4.11.3
rserver host APPS2-01
inservice
rserver host APPS2-02
inservice
ip address 10.4.12.2
rserver host APPS2-03
inservice
ip address 10.4.12.3
serverfarm host APPS
rserver APPS1-01
inservice
rserver APPS1-02
inservice
rserver APPS1-03
inservice
rserver APPS2-01
inservice
rserver APPS2-02
inservice
rserver APPS2-03
inservice
class-map match-any WEBAPPS_CLASS
match virtual-address 10.4.10.1 tcp any
match virtual-address 10.4.10.2 tcp any
match virtual-address 10.4.10.3 tcp any
Note: The real range is 99 not 3.
They have two rservers (apps1 and apps2). Each one has 3 virtual address.
Here is the problem...
Client wants to go 10.4.10.(2) and CSS loadbalance two real servers according to last subnet bit x.x.x.(2) Then it goes 10.4.11.(2) or 10.4.12.(2)
In CSS I think this is the default prediction method when range is used. But I can't find it in ACE 1.1(a). Is there any way to guarantee that the ACE loadbalance like CSS did? I realy need your advice. Thanks in advance.
ciscocsoc
Level 9
Level 9
If I've understood your requirement and you really need to carry the CSS implementation across then I think you need to create multiple rservers into multiple serverfarms. Then a class-map for each VIP with an associated loadbalance policy-map: Something like -
rserver host x01
inservice
rserver host x02
inservice
rserver host x03
inservice
rserver host y01
inservice
rserver host y02
inservice
rserver host y03
inservice
serverfarm host FARM-01
rserver x01
inservice
rserver y01
inservice
serverfarm host FARM-02
rserver x02
inservice
rserver y02
inservice
serverfarm host FARM-03
rserver x03
inservice
rserver y03
inservice
class-map match-any L4VIPCLASS-01
2 match virtual-address 10.4.10.1 tcp any
class-map match-any L4VIPCLASS-02
2 match virtual-address 10.4.10.2 tcp any
class-map match-any L4VIPCLASS-03
2 match virtual-address 10.4.10.3 tcp any
policy-map type loadbalance first-match LB-POLICY-01
class class-default
serverfarm FARM-01
policy-map type loadbalance first-match LB-POLICY-02
class class-default
serverfarm FARM-02
policy-map type loadbalance first-match LB-POLICY-03
class class-default
serverfarm FARM-03
policy-map multi-match L4POLICY
class L4VIPCLASS-01
loadbalance vip inservice
loadbalance policy LB-POLICY-01
class L4VIPCLASS-02
loadbalance policy LB-POLICY-02
class L4VIPCLASS-03
loadbalance policy LB-POLICY-03
There might be a slicker way of achieving what you want and I'm sure one of the ACE gurus will point it out if it exists.
Did you use the conversion tool on the ACE? It should have highlighted any parts of the config it couldn't cope with.
Cathy
First of all, Thanks for your quick reply.
I use CSStoACE conversion tool. And it says...
The range option of the ip address subcommand under service configuration is not converted. Only the first ip address would be converted. For each of the remaining ip addresses in the range, rservers will have to be created manually and such rservers will have to be added to the appropriate serverfarm also manually.
I aggree it can be done manually. But the range is 99 not 3. If CSS can do it without any additional configuration and if ACE is newer and better than CSS it should be a better way do it.
