CSS will not complete box-tobox redundancy
tholmes
Hello can someone please help.
I've had problems with the
commit_redundConfig "99.99.99.2" command
I've used the -f but its still not copying the config from the master to the backup, here is the output from the
commit_redundConfig "99.99.99.2 -d"
CSS11501#
Checking available disk space on systems ...
Checking the disk space locally before continuing with the script.
COMMIT_REDUNDANCY Version: 4.6
Verifying app and redundancy configs ...
Verifying that ip redundancy is activated on Master switch.
Verifying that app session is up with backup switch.
Making sure app session is up.
Seconds to wait before calling it quits: 120
Checking the disk space remotely before continuing with the script.
Checking local and remote switch versions ...
Storing the running code versions of the local and remote switch.
Storing the local switch's version.
Retrieving the remote switch's version.
Checking remote version for 4.0
Checking Master redundancy-config for redundancy-protocol set
and if so storing it in variable MASTER_IP.
Verify that the Ip Address specified is the Backup's Ip Address.
Checking Backup app session up....
Saving Master running-config to startup-config and archiving startup-config.
Copying running-config to startup-config.
Archiving startup-config.
Copying startup-config to a temp file tmp.cfg.
Swapping Master and Backup ip addresses in tmp.cfg for app
Checking for multiple APP sessions between redundant peers.
App Session IP: 99.99.99.2, Local IP address: 99.99.99.1
Checking IP Address size differences : <99.99.99.2> <99.99.99.1>
Adding APP session IP length difference to LOCALCONFIG byte size : 0
Adding APP session IP length difference to REMOTECONFIG byte size : 0
Removing CIRCUIT and INTERFACE modes from tmp.cfg.
Checking if ip redundancy master is set
Checking redundancy state....
Checking for SSL configuration ...
Working
Working
Using rcmd to copy tmp.cfg to a file on Backup switch.
Archiving copy to Backup's startup-config.
Archiving Backup's current startup-config.
Restoring startup-config (new copy) to startup-config.
Clearing running-config.
Script playing the copy script of the Master's running-config.
99.99.99.2 NOT_USED NOT_USED NOT_USED NOT_USED 0
Checking to make sure backup App goes down
Making sure app session is down.
Seconds to wait before calling it quits: 175
Copy success being verified by comparing byte sizes of archived running-
configs of the Master switch and the Backup switch.
Seconds to wait before calling it quits: 0
Stand By Switch's app session is not up.
Check for script commit_failure on the Backup.
CSS11501#
when I look at the backup CSS it has erased the app config completely! so I have to start again using the config below
expert
conf t
ip redundancy
app
app session 99.99.99.1
ip route 0.0.0.0 0.0.0.0 6.100.100.144 1
!************************* INTERFACE *************************
interface e1
bridge vlan 99
phy 100Mbits-FD
description "**** Failover Link to Stby CSS ****"
!************************** CIRCUIT **************************
circuit VLAN99
description "Link to Standby for Redundancy"
ip address 99.99.99.2 255.255.255.0
redundancy-protocol
I've checked for the script commit_failure on the Backup and cleared it but it still doesn't want to work
Any suggestions would be greatly appreciated
Regards Tony
It looks as if active CSS couldn't sense app session on the backup css.
You can try few things
run
show app session verbose
on both CSS and see if you get
"State: APP_SESSION_UP" on both CSS
"show redundancy" on both CSS and look for
"Number of times redundancy state changed to Master: "
If these changes are incrementing constantly
then there could be a link issue between the CSSs.
you can also remotely execute commands over session using
rcmd "any css command"
for e.g
rcmd 99.99.99.1 "sh clock"
to verify if app session is working.
Before running all the above tests make sure both CSSs are in same time zone and try changing the failover link to auto-negotiate on both CSSs.
Syed
Hello Syed,
Many thanks for the reply.
I initially set up the
ip redundancy
app
and the interface/circuit VLAN stuff on the backup CSS ok
When the app session is showing as 'up' I issue the commit command from the master, it all goes ok until the master wipes the config off the backup and then I lose the app session!
Really strange behaviour
Any ideas appreciated
Cheers Tony
