css11500 question: ssl proxy list problem
julxu
Level 7
Level 7
can the proxy list crash?  if so, how can I fix it?
today, I need add a few ssl-server commands into the list, but, I can not active, the error is:
Error in ssl-server 38: RSA Cert/Key Verify
%% Key file is in valid.
which the ssl-server 38 is not the one I added.
I have verify them and error is;
file xxxcert.pem does not exist
%% invalid key xxxkey
but, the file is existed, I changed the file name, and use a new name again, it works, and complains another one faulty.
do I have any way to audit or fix it? if so, please advice?
Any comments  will be a preciated
Thanks in advance
julxu
rodrguti_2
Level 3
Level 3
It seems it is the way you are uploading the file, what kind of file is this? is it a PEM, PFX?
Does the file have a passphrase?
If yes probably you are missing that when you are uploading the file.
If the file has passphrase, please send me the copy import command you are using.
Rodrigo.
