CSS11503 Management port connection loss
dale.cooke
Hi we run 2 x CSS11503 with box-box redundancy. I have configured both management ports with IP's and default gateways. The management ports work fine when the box is in "master mode" but as soon as it goes in to "ackup mode"I loose connection to the management port. It seems to me that when the box is in back up it shuts down it's TCP/IP stack??? Is there anyway to override this on the Management port?
Cheers
Gilles Dufour
the management port should not be down when the CSS is in passive state.
Are you sure the response from the CSS was going out via the management port ?
Where you in the same vlan of the management port ?
If not, did you configure a management route to reach your pc ?
Gilles.
