CSS11503 - Need help troubleshooting SSL connection
dclee
Level 5
Level 5
We run 2 CSS's here, one is prod and one is QA. Our QA is a CSS11503 and currently terminates 36 inbound SSL url's and
redirects them to a backend web server..All is working well.
But I am trying to add a new ssl rule and I'm having problems getting it to work.
I'm looking for a few troubleshooting commands that will allow me to see if the SSL traffic has reached the CSS as well as
if it has redirected the backend web traffic to the correct server.
Cheers
Dave
dclee
Level 5
Level 5
I notice that when I do a show service, its state is "down"
If the service is showing down, it means the CSS is not able to reach the service. By default, unless you have defined a different keepalive method, it will test reachability by pinging the IP address of the service.
Until the service status becomes "alive" connections will not be sent to this server.
In general, there are not many commands you can use for troubleshooting on the CSS. Most of the time, the best approach to see if a connection is working or not is doing a traffic capture on the client and the server. Apart from this capture, it is sometimes useful to do "show summary" to confirm all the rules are operational and "show flows" to see the currently established connections.
Daniel
